Hey guys I just got a daihatsu cuore l700 and I noticed that the pedal takes zero to no resistance to push it to around the middle point and then I can feel some resistance. Is that normal for this car or is something going bad I just changed the clutch
There should be some adjustment. Just keep some free play.
Welcome to the forums.
On mine the top 1/3 is light resistance but it is definitely there and then it builds in pressure after that until you feel the full engagement point around 60% of the way down.
If you are concerned about it slipping assess it on hill starts.
