Daihatsu Sirion M100 gear shifter repair kit
Hello there!
Long time no see… sorry about that. I’ve been lost in my work. Anyway, I have much play on my gear shifter, but I can’t find anywhere a repair kit for it. Does anyone know where I can find it?
Thank you.
have you check the bushes? they are probably worn and need replacing.
It is most certainly worn bushes as evilhighway said. In the past i have measured them up and just ordered sinter-bronze bearings the same size, its a very good upgrade!
Good question, i have the same issue.
When you have the massurments for the bushings could you post these? Would be a great help!
@Mick do you have the massurments?
I think it was just a flanged bushing O.D 13mm, I.D 8mm or something like that. I got some of the old plastic bushes at work I can measure up when I get a chance.
Once you have the correct measurements this is the kind of thing to look for
