###EF-Series Engines (660cc)
The EF-series is a 659 cc (0.66 L) version designed to replace the EB series engine when kei car regulations changed for 1990. It was first seen in the Daihatsu Mira when it was facelifted in March 1990. The bore is 68 mm (expanded from 62) and stroke is 60.5 mm. Having undergone a long development, a myriad versions of this engine have been developed, and fitted to a multitude of Daihatsu products. Production ended in December 2007, by which time the new KF engine had replaced the EF across the board. The EF was nearly as light as its predecessor, with a 2004 EF-SE clocking in at 68 kg (150 lb) - this with the added weight of modern emissions equipment and fuel injection.
###Engine Varients (EF)
| Varient |
Layout |
Induction |
KW |
@RPM |
NM |
@RPM |
Comp |
Fuel System |
Chassis |
| EF-CL |
6V SOHC |
NA |
29 |
6500 |
52 |
3500 |
9.5 |
Carb |
L200/210 (Mira) L500V/510 |
| EF-CL |
6V SOHC |
NA |
23 |
6400 |
49 |
3200 |
9.5 |
Carb |
Kancil 660EX |
| EF-CS |
6V SOHC |
NA |
29 |
5700 |
54 |
4500 |
9.5 |
Carb |
S82/83 (Hitjet/Atari) |
| EF-VS |
6V SOHC |
NA |
31 |
5700 |
55 |
4500 |
9.5 |
Carb |
| EF-ES |
6V SOHC |
NA |
31 |
6000 |
56 |
3500 |
10 |
EFI |
| EF-ES |
6V SOHC |
NA |
32 |
6100 |
58 |
3600 |
9.8 |
EFI |
S100/110 (Hijet), S120/130 (Atari) |
| EF-KL |
6V SOHC |
NA |
31 |
6800 |
53 |
4400 |
9.5 |
Carb |
L200/210 (Mira), L500 (Mira) |
| EF-NS |
6V SOHC |
NA |
31 |
5700 |
55 |
4500 |
9.5 |
Carb |
| EF-FL |
6V SOHC |
NA |
29 |
6300 |
52 |
3500 |
9.5 |
Carb |
L500S/510S (Mira) |
| EF-CK |
6V SOHC |
NA |
23 |
4900 |
50 |
3200 |
9.5 |
Carb |
K100 (Midget II 96.04-99.08) |
| EF-SE |
6V SOHC |
NA |
33 |
6400 |
55 |
3600 |
9.5 |
EFI |
L700/710, L900/910 (Move), L800/810 (Opti) |
| EF-SE |
6V SOHC |
NA |
35 |
6400 |
56 |
4800 |
9.5 |
EFI |
L250/260 (Mira, From 2002.12) |
| EF-SE |
6V SOHC |
NA |
25 |
5900 |
63 |
4000 |
10.5 |
EFI |
S200/210 (Hijet until 2002.01) |
| EF-SE |
6V SOHC |
NA |
33 |
5900 |
57 |
3600 |
9.5 |
EFI |
S200/210 (Hijet until 2007.12) |
| EF-SE |
6V SOHC |
NA |
24 |
4900 |
51 |
4000 |
9.5 |
K100 (Midget II) |
| EF-XL |
6V SOHC |
Turbo |
45 |
7000 |
84 |
4000 |
8.3 |
Carb |
L200v (1990-1992, TRXX) |
| EF-XS |
6V SOHC |
Turbo |
45 |
6000 |
85 |
4000 |
8.5 |
Carb |
| EF-TS |
6V SOHC |
Turbo |
47 |
6000 |
86 |
4000 |
8.3 |
EFI |
S82/83 (Hitjet/Atari), S120/130 (Atari) |
| EF-HL |
12V SOHC |
NA |
37 |
7500 |
52 |
4500 |
10 |
Carb |
L200/L210 (1990-1995) |
| EF-EL |
12V SOHC |
NA |
40 |
7000 |
57 |
4000 |
10 |
EFI |
L200/210 (1990-1994), L500/510 (1994-1995) |
| EF-JL |
12V SOHC |
Turbo |
47 |
7500 |
92 |
4000 |
8 |
EFI,IC |
L200/L210/220 (1990-994, TRXX) |
| EF-GS |
12V DOHC |
NA |
32 |
5900 |
59 |
4400 |
10 |
Carb |
| EF-VE |
12V DOHC |
NA |
43 |
7600 |
64 |
4000 |
10.5 |
EFI |
Mira,Move,S100/110 (Hijet), S120/130 (Atarti) |
| EF-VE |
12V DOHC |
NA |
35 |
5900 |
63 |
4000 |
10.5 |
EFI |
S220/230 (Atarti) |
| EF-VE2 |
12V DOHC |
NA |
38 |
6800 |
62 |
4000 |
11.3 |
EFI |
L700 (Mira "TV", 1998-2002) |
| EF-ZS |
12V DOHC |
NA |
34 |
6100 |
61 |
4000 |
10 |
EFI |
| EF-VD |
12V DOHC |
NA |
44 |
7600 |
65 |
4000 |
11 |
EFI, DI |
L250 (Mira 2002-2006) |
| EF-RS |
12V DOHC |
Turbo |
47 |
5900 |
98 |
3500 |
8.5 |
EFI |
S120/130 (Atarti 1997-1999) |
| EF-DET |
12V DOHC |
Turbo |
47 |
6400 |
107 |
3600 |
8.5 |
EFI |
L900/910 (Move 1998-2002), L750/760 (Naked), L800/810 (Opti) |
| EF-DET |
12V DOHC |
Turbo |
47 |
6400 |
103 |
3200 |
8.5 |
EFI |
L150/160 (Move 2002-2006), L550.560 (Move Latte), L750,760 (Naked 2003-2004) |
ECU Models
| Varient |
ECU Number |
Chassis |
Varient |
ECU Number |
Chassis |
| EF-ES |
EF-VE |
| EF-ES |
EF-VE |
| EF-SE |
EF-VE2 |
| EF-SE |
EF-ZS |
| EF-SE |
EF-VD |
| EF-SE |
EF-RS |
| EF-TS |
EF-DET |
| EF-EL |
EF-DET |
| EF-JL |
112000-16630 |
L200s |
Service Details
| Varient |
Oil Filter |
Spark Plug |
Air Filter |
Fuel Filter |
Spark Gap |
Timing |
| EF-CL |
| EF-CL |
| EF-CS |
| EF-VS |
| EF-ES |
| EF-ES |
| EF-KL |
| EF-NS |
| EF-FL |
| EF-CK |
| EF-SE |
| EF-SE |
| EF-SE |
| EF-SE |
| EF-SE |
| EF-XL |
| EF-XS |
| EF-TS |
| EF-HL |
| EF-EL |
Z386 |
Denso - QL22TR-S (Standard Plug) |
| EF-JL |
Z386 |
NGK - BCPR7EDIX |
| EF-GS |
| EF-VE |
| EF-VE |
| EF-VE2 |
| EF-ZS |
| EF-VD |
| EF-RS |
| EF-DET |
| EF-DET |
