From your wheel alignment data I’m not sure what the rear toe in is. Should be toed in about 1mm.
If changing rear tires made some diff then I’d explore tires more as an issue.
Sporing = toe in/out
get your rear shocks tested.
what tyres did you put on the rear?
Are you still having problems with the car? Or did you fix it?
Unfourtunately yes. But at the moment it’s not really important as i’m messing with the alignment.
