Midori (Green Copen)
Nice update mate and those tail lights do look great. Such a fortunate karma of drink and buyee! lol
The weather’s been amazing lately. Having a little cabrio really is a blessing when the sun’s out!
Boost issues
I was dealing with intermittent boost drops for a while, especially on colder days. My guess was something related to temperature. Expanding metal sealing things back up once warm.
The only hose I hadn’t properly checked (without taking half the car apart) was the one running from the turbo to the back of the intercooler. That one has been a recurring problem. I’ve replaced it twice before because the end tends to deform when clamped down. Tighten it too much and it starts to open up, but if you don’t tighten it enough, it won’t hold pressure during a leak-down test.
Since it was also one of the last OEM pieces left in the intake system, it became my main suspect.
Unfortunately, it’s not a simple hose. It’s a very specific shape and size. I tried using a generic 90° hose with couplers, but that just introduced more failure points and added unnecessary tension. Not ideal.
Eventually I found a proper replacement from Samco (TCSDAI-1). Weirdly enough, I had to order it from Japan via Nengun, even though Samco is UK-based. There was just zero stock anywhere in Europe, not even directly from Samco. Somehow Nengun managed to backorder it (probably straight from them :grinning_face_with_smiling_eyes:).
And honestly it’s a nice little upgrade. The diameter is slightly smaller and the ends are a bit longer, which means it sits further over the intercooler pipe. Much more secure, and way less likely to slip off again.
Bit of a long story for a “simple” hose, but these OEM parts are 20+ years old now, and proper replacements aren’t exactly easy to find anymore.
Anyway… problem solved. Boost is now rock solid again at 1.0–1.1 bar.
Sun visor delete
I’ve had the sun visors out for a while now. They always annoyed me, and I never really used them anyway since I’m almost always wearing sunglasses.
The only downside: it leaves three holes right in your line of sight.
Luckily, a friend of mine 3D printed some simple blanking caps, and they clean it up perfectly.
The STL he used: https://www.thingiverse.com/thing:7282825
That’s cool to share the stl although I would never do a visor delete in Australia. Especially where I live. We need all the shade we can.
Well done on finding that hose I remember that one was a bit of a prick when I have my copen also. If you do get future issues maybe see if you can get some aluminium piping or steel and use some silicone joiner’s. Just an idea but hopefully one you never have to deal with again.
Good to see that boost needle where it should be. :slight_smile: and great to see an update.
Enjoy the sun :slight_smile:
Shade in a cabrio? My roof is never on lol.
Well as I mentioned, I tried couplers with 90s but it’s just suboptimal. Hopefully I’ll never have to touch it again hehe.
Polishing the Copen
Recently I gave the Copen a polish with a one-cut compound and finishing pass. The goal was to get rid of most of the wash swirls and bring some of the shine back to the paint.
The paintwork definitely isn’t perfect anymore, it is 21 years old after all, so some defects are to be expected. Still, I think it came out really well.
EMWalhalla
I also joined the Dutch Copen Treffen group for EMWalhalla this year. I’ve been attending for a few years now, but this was the first time going with the Copen.
Oil change and check-up
It’s been around 8000 km since the engine rebuild, and there is still a bit of wear-in visible on the magnetic sump plug. Thankfully it’s all very fine and fuzzy, so I’m not too concerned about it. There’s noticeably less material on it compared to the previous oil change as well.
I’m now back to my regular oil change interval of roughly 5500 km, which is what I used before the rebuild. The engine also isn’t using any oil at all, not a single drop. Surprisingly, it didn’t consume any oil during the break-in period either.
I’ve also switched back to my regular engine oil: Castrol Magnatec 5W-30 A3/B4. During the break-in period I used a more basic oil to help the piston rings bed in properly and to avoid unnecessary additives. Now that the engine has settled in well, I’m comfortable going back to a higher quality fully formulated oil for normal use.
I specifically went with an A3/B4 oil instead of a C3. The JB-DET doesn’t have a catalytic system or DPF setup that requires low-SAPS oil, so I’d rather run the slightly “fuller fat” A3/B4 package with its higher HTHS protection and additive content. Especially on a small turbocharged engine that sees spirited driving from time to time.
Next up are the rear brakes, which are somehow still factory original. New shoes and wheel cylinders arrived recently. I also need to replace the front wheel bearings, as one of them has started making a slight noise.
To be continued!
Small update; I had some oil mist covering the valve cover because of the open filter. It has never done that before the rebuild but with the compression being what it should be I think what goes past the rings into the PCV system is pressurised a lot more than before :laughing:.
In any case; a good catch can is never a bad thing. It fits nicely around the overflow reservoir. Engine bay is looking nice :smiling_face_with_three_hearts:
Hello everyone reading this
It has been a full year today since we first started the rebuilt engine; And it’s still running like a dream.
It’s been a good 12.000km this year so I sure enjoyed it to the max.
Today I went for yearly inspection and it passed without advisories yet again.
But… I still have some welding work to do. So that’s coming in the next few months.
A few weeks ago I installed a fresh intercooler that isn’t leaking… The original 22 year old one gave out.
I’ll be driving my other car (Lada Niva) this winter mostly, Copen will get some body TLC.
That’s a dinky intercooler, clearly I am thinking in sizes too large and inefficient for a small engine.
Awesome work on 12 months of driving and a fresh MOT.
Oh and I love the Niva, not a car I saw a lot of but there was one in my street growing up as a kid.
It’s the same size as the original, just a little denser and thicker. Except without the plastic top and bottom. I doubt it would benefit from anything bigger.
With the temperatures being around 9C right now I sometimes already see ice forming on the intercooler. So it’s defo doing it’s job.
