So the gearbox of our 1.5 sirion is starting to go at 210k. Which sucks as the timing is not ideal (when is it?) Does anyone know if the gearbox of a materia is the same? The engines seem the same so I would figure the gearbox aswell?
The ratios might be different, but it’ll fit and work.
Seems like I’ll be changing a gearbox…
Thanks allot
its longer if you fit a materia box on a sirion 2
Longer as in the gearing? Of the gearbox itself?
final ratio in the materia is longer
