1krfe using more fuel per 100km
Why is my 1KRFE using more fuel?
Yes I am using E5 fuel
So far I tried cleaning up the map sensor.
Is it a:
Clogged cat?
Leaking exhaust V
Sensors not functioning properly?
Brakes binding
Ignition coils worn out?
too heavy engine oil? I am using 5W50 atm. Maybe 5w20 would work better?
I would love to have first hand knowledge of the 1KR-FE but Daihatsu was pulled out Australia in 2005.
Run whatever is the recommended oil based on the temperature of your local climate, thinner grade oils for colder conditions.
Check that the air filter being blocked or excessively dirty would be my first go to, as a dirty filter will massively restrict the engine’s ability to breathe.
its all checked. Cat is not good I guess. Exhaust leak yesterday. I have renewed the rest
If you have an exhaust leak in the manifold before the 02 sensor this could explain why the car is running rich.
does a decat also not help?
Oxy sensor would be my pick with using fuel with ethanol .
Defenitely don’t use such thick engine oil!!! The correct oil is 5w30.
I doubt it’s a clogged cat or bad coils, cause then you would lack serious power.
Binding brakes you should be able to feel.
It could be a sensor or injectors that are stuck open a little.
How bad is your fuel consumption?
A little side note… My previous L7 used noticeably more fuel on E5 than E10 (with my driving style at least).
E5 I use. does a decat loose backpressure?
Backpressure is a false myth, exhausts don’t need backpressure. If you have removed the cat brick from a manifold and have not reduced the internal size of the void it will kill engine power.
E5 from which gas station?
Yesterday i put E5 in my car as usual, and lost a lot of power and it started consuming much more. I will never get my fuel from that gas station ever again! (It was a texaco, in case you’re wondering).
Vanraak/Shell/Janssen Tighlet, local pump my project cars 99% use this fuel.
They buy from Shell.
Anyway I got a small leak between the lambda sensors so will fix this first
I got 4.7l/100km average
after repairing the leak on my exhaust,
installing catalyst back,
changing my oil to 0W20
and cleaning the MAP/IAT sensor combi with maf cleaner.
I also increase the tyre pressure by 0.5bar to 2.5bar
Will try and see how far the AVG L/100km will drop from here.
with E5 98 it dropped to 3.8L/100km with E10 its 4.6L/100km on 6000km run
Yeah that tire pressure sure has improved things xD
also cleaning the MAP sensor helps and using 0w20 oil
4.1l/100km avg
Map sensor went dirty and now again 4.7l/100km average
Cleaned map sensor and intake manifold lets see
