4x100 conversion on G11
Looking at doing a conversion to 4x100 pcd on my white charade. If I remember correctly I could use G100 struts and hubs for the front and G100 rear hubs? Was just wondering if the hubs of a Sirion would fit on as I have a Sirion sitting out the back. Any help appriciated.
Dean.
Ask Daniel Graham on facey @Nommo his is now 4x100
Pull the Sirion rear hubs off and do some measuring. You need inside diameter of both bearing and then the crush distance (separation between the bearings). Final thing will be offset
Thanks Guys, Have spoken to Daniel about the conversion and G100 is an easy swap over. I just wasn’t sure if Sirion bits may have fitted, mainly front, rear shouldn’t be too difficult (I hope) :grin:
