Aisan carburetors 877xx on AB-30 and AD-10
Hello everyone. I am trying to figure out if the carburetors on the AB-30 (L55) and the AD-10 (L60) Engines are identical. I have detailed instructions on disassembly for the AB 8774x carb but mine on the AD is a 87758. I wonder if the instructions match and if I can use the same repair kit, as there is no dedicated one for the L60 to be found. They look identical, but I’m sceptical about that difference in model numbers…
Does anyone know more about those Aisan carbs?
@DaleJeffree ???
The only difference in the carbs is the fuel jets.
Apart from that they are the same. Same repair kits
