Hello again. How hard would it be to swap in a fuel injected applause engine into my g200 charade . Which is a 1300cc carb.
I’d guess it would be a matter of swapping the complete engine loom and ecu. The original box may bolt up to the new block, otherwise you’ll have to swap the entire drive line then you may hit a problem with driveshafts and cv’s etc.
Is it manual or auto, same as your car?
You will also need to swap the fuel tank or get a swirl pot fuel pump setup to sort out the high pressure fuel required for EFI.
