C-Series Engines
##Daihatsu C-Series Engines
Please note that on a mobile device you will not see the entire tables listed in this thread
The Daihatsu C-series engine is a range of compact three-cylinder, internal combustion piston engines, designed by Daihatsu, which is a subsidiary of Toyota. The engines range from 843 to 993 cc and have been manufactured in petrol and diesel-driven series. They have cast iron engine blocks and aluminum cylinder heads, and are of either SOHC or DOHC design, with belt driven heads. The engine first appeared in the all-new Daihatsu Charade in October 1977, in “CB20” form.
Most common is the 1-liter CB, which was also available as the diesel CL. There is an 843 cc version called the CD and the extremely rare 926 cc homologation special called the CE.
(CB-80 Turbo)
(CB-60 Turbo)
(CB-23)
(CL-50 Turbo Diesel)
##CB-Series (993cc)
The 993 cc (1.0 L; 60.6 cu in) CB engine appeared in October 1977, for the then-new Daihatsu Charade. It features 120 degree crank throws and a counter-rotating balance shaft. Bore and stroke are 76.0 mm (2.99 in) and 73.0 mm (2.87 in) respectively. It also incorporated mother concern Toyota’s lean-burn design to run cleaner.
It was also fitted to the Daihatsu Hijet, sometimes referred to as the “Daihatsu 1000” when equipped with this engine. It was fitted to the S70/75/76 and S85 models. Italy’s Innocenti also used this engine for many variants of their Minitre/990/Small range of cars. De Tomaso was also the first to turbocharge this type of engine, first for a Daihatsu show car and later for the Innocenti Turbo deTomaso.
###Engine Varients (CB)
Varient Layout Induction KW @RPM NM @RPM Comp Fuel System Chassis
CB-10 6V SOHC NA 40 5500 77 2800 8.7 Carb G10 Charade (1980-1983)
CB-11 6V SOHC NA 40 5500 76.5 2800 9.1 Carb G10 Charade (1980-1983)
CB-12 6V SOHC NA 40 5500 76.5 2800 9.5 Carb G11 Charade
CB-20 6V SOHC NA 37 5500 73 3000 8.7 Carb G10 Charade
CB-20 6V SOHC NA 38 5600 75 3200 9 Carb G10 Charade
CB-22 6V SOHC NA 44 5600 81 3200 9.5 Carb G11v Charade
CB-23 6V SOHC NA 38 5600 75 3200 9.5 Carb G100 Charade
CB-24 6V SOHC NA 38 ? 75 9.5 Carb G202 (1993-1996)
CB-31 6V SOHC NA 44 5600 80 3200 9.1 Carb G10 Charade (1979-1980)
CB-32 6V SOHC NA 44 5600 81 3200 9.1 Carb G10 Charade (1980-1983)
CB-33 6V SOHC NA 44 5600 81 3200 9.5 Carb G11 Charade
CB-34 6V SOHC NA 40 5500 76.5 2800 9.5 Elec Carb G11 Charade (CF - 1983-1985)
CB-35 6V SOHC NA 40 5500 76.5 2800 9.5 Elec Carb G11 Charade (CX - 1985-1987)
CB-36 6V SOHC NA 37 5600 75 3200 9.5 Carb G100 Charade
CB-37 6V SOHC NA 40 5600 78 3600 9.5 Carb G100 Charade
CB-41 6V SOHC - Hoizontal Mount NA 32 5200 72.6 3200 8.7/9.0/9.1 Carb S75/76 (Hijet 1983-1986), S86 (Hijet 1968-1988), S85 (Hijet 1993-1997)
CB-41 6V SOHC - Hoizontal Mount NA 33 5200 74 2400 8.7/9.0/9.1 Carb S75/76 (Hijet 1983-1986), S86 (Hijet 1968-1988), S85 (Hijet 1993-1997)
CB-42 6V SOHC - Hoizontal Mount NA 35 ? ? ? 9.5 EFI S86 (Hijet 1994-1998)
CB-50 6V SOHC Turbo 59 5500 87 3500 8 Carb G11 Charade (DeTomaso 1983-1987)
CB-51 6V SOHC Turbo 54 5600 80 3600 8 Carb G100 Charade (1987-1988)
CB-60 6V SOHC Turbo 50 5500 78 3200 8 Carb G11 Charade Turbo (Turbo DeTomaso)
CB-61 6V SOHC Turbo 50 5500 78 3200 8 Carb G100 Charade Turbo
CB-70 12V DOHC Turbo 77 6500 96 3500 7.8 EFI GTTi Charade (1987-1993)
CB-80 12V DOHC Turbo 74 6500 96 3500 7.8 EFI GTTi Charade (G100)
CB-90 6V SOHC NA 40 5750 59 3000 9.5 EFI G100 Charade (1987-1993)
CB-90 6V SOHC NA 40 5200 58 3600 9.5 EFI G100 Charade (1989-1992)
###ECU Models
Varient ECU Number Chassis
CB-42 ? ?
CB-70 ? ?
CB-80 ? ?
CB-90 ? ?
CB-90 ? ?
###Service Details
Varient Oil Filter Spark Plug Air Filter Fuel Filter Spark Gap Timing
CB-11 ? ? ? ? ? ?
CB-12 ? ? ? ? ? ?
CB-20 ? ? ? ? ? ?
CB-20 ? ? ? ? ? ?
CB-22 ? ? ? ? ? ?
CB-23 ? ? ? ? ? ?
CB-24 ? ? ? ? ? ?
CB-31 ? ? ? ? ? ?
CB-32 ? ? ? ? ? ?
CB-33 ? ? ? ? ? ?
CB-34 ? ? ? ? ? ?
CB-35 ? ? ? ? ? ?
CB-36 ? ? ? ? ? ?
CB-37 ? ? ? ? ? ?
CB-41 ? ? ? ? ? ?
CB-41 ? ? ? ? ? ?
CB-42 ? ? ? ? ? ?
CB-50 ? ? ? ? ? ?
CB-51 ? ? ? ? ? ?
CB-60 ? ? ? ? ? ?
CB-61 ? ? ? ? ? ?
CB-70 ? ? ? ? ? ?
CB-80 ? ? ? ? ? ?
CB-90 ? ? ? ? ? ?
CB-90 ? ? ? ? ? ?
###CD (843 cc)
The 843 cc CD engine was usually fitted in export market Daihatsu Hijets (also known as the “Daihatsu 850”). Bore and stroke are 70.0 mm (2.76 in) and 73.0 mm (2.87 in) respectively. Chile (and possibly other markets) also received this engine in the Daihatsu Charade, called the “G20” or “G21” when thus equipped.
###CL (993 cc diesel)
The turbodiesel CL50 engine
The diesel version of the CB shares that engine’s dimensions, for 993 cc (1.0 L; 60.6 cu in). It appeared in 1983, along with the second generation of the Daihatsu Charade. There was also the CL50, a turbocharged version producing 50 PS (37 kW).
Original Source: https://en.wikipedia.org/wiki/Daihatsu_C-series_engine
Could be my old age… but the photo of the CB-23 is an EFI yeah?
Didn’t know the CB-23 came with EFI, thought it was only CB-70s and up?
could be the USA only version called a CB90, basically a cb233 with efi because of the anti pollution laws
@darkaxi0m the benifet of the wiki, anyone can edit it and make changes :slight_smile:
Got this from Nathan Munns website. His website is closing this year.
This is CB80 related.
Specifications and Data
Commonly requested information is highlighted in Bold
Engine: CB-80 (worldwide market designation, Mostly non-Catalyst but a few countries had Catalyst version),
        CB-70 (JDM market, All Catalyst)
993cc.
Bore 76.00mm, (Wear limit 76.03mm)
Stroke 73.00mm
Compression Ratio 7.8:1
Cast iron block - Height 206mm .
Bore taper limit 0.10mm
Block Deck Surface max distortion 0.10mm
4x Main bearings, 52.000mm - 52.010mm main bearing housing.
Crankshaft Thrust Clearance 0.02 - 0.22mm (limit 0.30mm)
Crankshaft Width between thrust washer contact surfaces 23.130mm - 23.000mm
Crankshaft thrust washer thickness 1.990mm - 1.940mm
Crankshaft Width between crankpins 25.20mm - 25.00mm
Crankshaft maximum runout 0.06mm
Crankshaft Main bearing Journal 47.992mm, wear limit 47.962mm
Main Bearing oil clearance 0.020 - 0.070mm
Crankshaft Conrod journal 42.992mm, limit 42.962mm
Conrod Big end housing 46.000mm - 46.010mm
(vital to check this size and roundness if you have had a big end bearing failure)
Conrod bearing oil clearance 0.024mm - 0.070mm
Conrod centre to centre length 125.00mm
Conrod small end for piston pin 19.00mm
Conrod small end width 22.00mm
Conrod Big end width 24.80mm - 24.85mm
Conrod Thrust clearance 0.15mm - 0.45mm
Conrod Weight 572g
Pistons. Flat top crown, semi forged (high pressure cast) with 1mm deep indents for inlet valves.
Compression height 31.00mm
Piston to Cylinder clearance 0.030 - 0.065mm (limit 0.12mm)
Piston Rings, 1st ring 1.5mm thick x 2.9mm depth, 2nd 1.5mm x 3.15mm, Oil 2.8mm x 2.6mm
Ring gaps, 1st ring 0.35 - 0.45mm (limit 0.70), 2nd 0.28 - 0.40 (limit 0.70), Oil 0.20 - 0.70 (limit 1.1mm)
Side clearance 1st 0.05mm - 0.09mm, 2nd 0.02mm- 0.06mm, Oil 0.01 - 0.03mm
Piston Pin 19.00mm. Oil clearance piston pin to piston 0.03mm maximum
Flywheel weight 6.4kg
Flywheel step height (clutch cover mounting surface to flywheel friction surface) 23mm
Flywheel dimple for Ignition timing , 10 BTDC
Engine Valves.
Inlet 107.0 length (limit 106.2mm), 30mm diameter. Stem 6.0mm
Exhaust 107.2 length (limit 106.4mm), 26mm diameter, Stem 6.0mm
Valve seat recession. Inlet 4.23mm maximum, Exhaust 5.30mm maximum
Valve face seat angle 45.5 degrees.
Valve head minimum thickness. Inlet 0.7mm, Exhaust 0.8mm
Valve guide to valve stem oil clearance. Inlet 0.025mm - 0.08mm, Exhaust 0.030mm - 0.09mm
Cylinder Head height 119.00mm (useful to check how much a head has been previously skimmed)
Head Surface maximum distortion 0.10mm
Cylinder Head gasket - Composite graphite with steel firing rings 1.25mm thickness
Timing belt 1240mm length, 155 teeth, 19mm width, 8.0mm teeth pitch.
Number of belt teeth between pulley timing marks:
Inlet camshaft pulley to exhaust pulley, 44 teeth
Exhaust pulley to crankshaft pulley , 51 teeth
Crankshaft pulley to inlet camshaft, 60 teeth
Camshaft Journals 28.00mm
Camshaft bearing oil clearance 0.025mm - 0.066mm (Limit 0.16)
Camshaft Thrust clearance, 0.20mm maximum
Camshaft lift Inlet 7.60mm
Camshaft lift Exhaust 7.20mm
Camshaft Lobe height inlet 39.65mm - 39.55mm (limit 39.40mm)
Camshaft lobe height exhaust 39.25mm - 39.15mm (limit 39.00mm)
Camshaft Runout 0.03mm maximum
Valve adjusting shims 25.00mm diameter (some motorbikes also use this size)
Valve lifter 29.985mm - 29.975mm width
Valve lifter oil clearance 0.015mm - 0.046mm (limit 0.070mm)
Valve clearances for COLD engine adjustment setting (example cylinder head rebuild)
Inlet. 0.16-0.17mm
Exhaust 0.21-0.22mm
Valve clearances, checking when HOT operating temperature, (coolant temp minimum 80c)
Inlet 0.27mm (0.22 - 0.32 acceptable)
Exhaust 0.32mm (0.27 - 0.37 acceptable)
Valve springs 45.9mm height, 21.1mm width. Length when fitted 35.0mm, load 23kg.
Spring constant 2.1/2.72 kgf/mm
Turbocharger IHI RHB51 , model VQ10 1987-1989, VQ17 (Coolant cooled 1989-1993)
Compressor wheel 5/5 blades. Inducer 31.5mm, Exducer 51mm
Turbine wheel 9 blades. Inducer 50.4mm, Exducer 35mm
Turbine housing A/R P12
Wastegate actuator starts moving 7-8psi
Boost pressure (solenoid controlled) 10.3 - 10.7 psi (0.71 - 0.73 bar)
Safety overboost cutout 12.7 - 13.1psi (0.87 - 0.9 bar) if exceeded for 0.8 second
Dashboard Boost indicator light on at 4 psi
Fuel injectors - DENSO 195500-1610
295cc measured at GTti 2.55bar fuel pressure. (320cc at industry standard 3 bar)
High Impedance 12.5 - 13.5ohm
Batch Firing.
Throttle body diameter 35mm (measured behind butterfly)
Clutch friction disc 180mm outer, 125mm inner. Woven Organic.
Made by Daikin-Exedy.
6 hub springs.
Friction disc thickness 3.0mm (flywheel side), 3.2mm (Pressure cover side),
Marcel spring metal thickness 0.55-0.65mm
Clutch disc thickness uncompressed 7.4 - 7.7mm
Disc thickness when fitted (marcel spring fully compressed flat) 6.8 - 7.0mm
Wear limit of friction, 0.3mm above rivets
Friction disc weight, 0.72kg
Clutch Pressure Cover factory fitted made by Daikin-Exedy.
Clamp load as fitted new 310kg.
Raising to peak of approx 380kg at optimum wear point.
Clutch cover weight 2.05kg
Spark plug cables, standard type HT cable - 7mm resistive carbon core.
Spark plugs. Twin ground electrodes for longer service life. Factory fit was Denso W20ETRL .
Gap is preset at 0.9 - 1.0mm and can’t easily be adjusted.
(CB70 Denso W20ETL same but non resistor)
NGK equivalent BPR6EKN (these have a 0.8mm gap)
Cooler heat range plug Denso W22ETRL, NGK BPR7EKN
Replace 15,000 miles
Modern Iridium type spark plug upgrades…30,000 miles life
NGK - BPR6EIX
NGK - BPR7EIX
Denso IridiumTT - IW20TT (Very long life)
Denso Iridium Power - IW20
Denso Iridium Power -IW22
Conventional electrode type plugs also work perfectly OK and are cheap, but best replace every 6000-8000 miles.
NGK BP6ES, BP7ES (non resistor) or BPR6ES, BPR7ES (resistor)
Engine oil.
Use any modern quality latest rated API/ACEA. Fully synthetic or semi synthetic prefered but not essential if changes are regular.
Recommended oil grades 0w 40, 5w 40, 10w 40, 5w 50, 10w 50.
Total Capacity 3.3 litres, Oil change without changing filter 2.7 litres, With filter 3.1 litres.
NEVER ALLOW OIL LEVEL TO DROP DOWN FROM FULL ON DIPSTICK. ALWAYS KEEP IT FULL.
BIG END BEARING FAILURE SEEMS MORE COMMON WHEN OIL LEVEL HAS BEEN ALLOWED TO DROP, EVEN HALFWAY ON DIPSTICK IS RISKY.
Gearbox oil. 75w 85 or 75w 90. GL4 or synthetic GL4/5
Capacity 2.1 - 2.2 litres
Brake fluid. DOT 4, Super DOT 4
I hope you let him know he is welcome to put any info in here he would like to share and keep :slight_smile:
