Coilovers for Sirion M100
Hello there! :crazy_face: I was searching the net for coilovers for my Sirion M100, but I didn’t find any… :unamused:
However, I found coilovers for Sirion M300! Do they fit? As far as I can tell, from the photos of the product, they have the same shape as the KYB I have already on. Any suggestions, ideas and solutions? :grin:
Not a quality item,. They will let you adjust ride height, however, they are more “bling” than performance, tend not to last long and any rebound adjustment is not linear. BC Racing is probably the best entry point for a good shock/damper.
@Mr_Gormsby, I found for Sirion M112S. Do they fit M100?
https://www.bc-racing.co.uk/applications/diahatsu-coilovers/daihatsu-sirion-m112s-89-04.html
There will be Sirion owners here that can confirm. @Mick should know. Front very likely would. Also ask BC
Thank you @Mr_Gormsby for your suggestions and your time! Much appreciated. :handshake:
Fronts will 100% fit.
Rears are uncertain.
The problem is, they are listed for a Sirion M112 which is AWD, however the last time someone enquired about them it turned out they were actually for FWD Sirion.
I’m not sure if they have changed in the meantime.
The difference between the AWD Sirion (M110, M111, M112) and FWD Sirion (M100, M101) are the rear shocks. The AWD has a Clevis mount rear bottom, and the FWD has an Eyelet Mount rear bottom. The Kit from BC appears to be for the FWD Sirion as the rear shocks have eyelets.
I would suggest contacting them and confirming again.
Ebay pic shows a rear that is M100. https://www.ebay.com.au/itm/BC-Racing-Coilovers-Daihatsu-Sirion-M112s-/372804900420
As Mick said the AWD has the clevis on the shock/damper. The M100 will have the Clevis on the suspension beam.
BC Racing will often use ‘generic’ pictures in their AD’s as I was rather confused when buying mine as the advertised picture looked nothing like the actual kit that arrived. Don’t rely on their pictures as any form of guide as can be seen below but contact them via email and get it in writing they have a kit for the M100.
If you call them they will clarify if the kit will fit as expected.
For example they advertise this for the Cuore, which has rear coilovers but we know the Cuore is separate rear strut and coil;
https://justjap.com/bc-racing-coilovers-daihatsu-mira-gino-cuore.html
but once I emailed and then phoned them they advised this was the correct kit ZF-07-VM, but again the picture is wrong as the rear strut should have eyelet at each end;
The kit that actually arrived was different from any of the Advertised pics;
**Importantly the did send the correct kit for my car irrespective of the advertised pictures!
This looks like a good site to contact in the UK “For competitive quotes including fitting on all BC Racing Suspension, please contact us via telephone on 01925 822 266 or via email to enquiry@tuningdevelopments.co.uk – We will look to price match any like for like quote on BC Racing Coilovers, so try us! Where we can, we will!”
http://www.tuningdevelopments.uk/index.php?cPath=690_702
http://www.tuningdevelopments.uk/product_info.php?products_id=1622
The bloke on FB, Chris, had emailed them and they sent him that photo so he could confirm wether or not they would fit his AWD Sirion. It appears to be the same kit you bought, which appears to be often misadvertised as a kit for the M112, which is AWD, hence all the confusion. Long story short, the BC kit for the Sirion is for the FWD variants.
To add onto this, here in Australia that BC kit is advertised for both M112S and M101RS (FWD) as can be seen here: https://bcracing.com.au/zf-03-vm
It does look the same - the important thing is getting it in writing so if the wrong kit comes you can prove that they stated it was the correct kit and should either get a replacement swap over or a send back refund. In Australia they said there are so many kits that they don’t have photos of the all of the potential different set-ups and so just use generic photos. I explained it makes it very confusing for customers and could result in a lost sale as they think the product is not suitable, he passed it onto management but nothing has changed.
So an email and phone call is important before any purchase.
Any idea where we can buy the Spare parts and the Paint for Royal Blue Sirion (M100) tired searching over google too hard to find it over. This is my first car and want to make it look good and unique in the road.
Welcome. Please go to the New People section and post an introduction and perhaps some pictures. That might help with getting attention and help with the parts. Those who put in a little effort are more likely to get help than those who only visit when they have a question they need answering.
With paint, go to your local automotive paint supplier. On the Gold Coast I’ve used Harts for over twenty years, they are extremely helpful.
