Hi, my MOT just failed on a front coil spring on my 2008 Copen - does anyone know if any other springs are compatible please or have a part number so I can have more luck with an online search in the UK?
I need to do a couple of 4 hour round trips shortly and I need HotWheels out of the garage asap.
Thanks in advance
JJ
If its just the spring then L251, L7,L6, L5 and L2 should fit. I would put both sides on. If its with the shock the L7 would be the closest i would think.
Depends how fast you need them, but for OEM parts try amayama.com.
A cursory google search has thrown these guys up too: https://www.onlineautomotive.co.uk/car-parts/Daihatsu/Copen/Steering-and-Suspension/Coil-Springs
IF the part number is to be believed, a Kilen KN50601 is also compatible with the rear of an Alfa Romeo 147 too? And there are loads of them on ebay. Thats a big IF though. Likewise Kilen KN10660 is fitted to loads of Renaults and other makes too, also available cheaply.
Also, loads listed here: https://www.euspares.co.uk/parts-catalog/coil-springs-10213/daihatsu/copen
