Custom coilovers
Hi fellow l2d members,
I have got a question about coilovers.
Its about an charade g100 sedan.
Over here in Holland its very hard/expensive to get coilovers for an charade.
Are there any other models that will fit with minor work ?
Dont mind a litle bit of fabrication but i need a good base to start with.
Kinds regards,
Viktor
You can order parts from Yahoo auctions Japan through a website called buyee, they ship to Europe. Also check eibach and bilstein, I thought I saw something there for charade when I was looking for Sirion suspension. I have also heard of someone using Nissan s13 coilovers on a Daihatsu with only a little modification but I guess you would also have difficulty finding those parts over here…
Another place to look would be a company called GAZ shocks over in the UK.
Thx for the quick reply,
But im not looking to spend 1000 euro on shocks and springs.
Ive heard of using the front ones from a golf 2 but i would need to buy two sets.
i have customyzed a Original set , 5cm lower than Original drives great
Do you have a problem with leaking shocks after putting other springs on there?
no, adjusted topmount so that that is not possible
Cool, thanks for explaining
