Hi their. I’m swapping my 1300cc to a 1600 cc engine from an applause. I have a manual transmission. I’ve seen the difference in the cv joint thickness on the applause. Should I change the 1300cc cv joints to the thicker applause cv joint or will they hold up ?
It would depend on what you plan in the way of driving habits. If you drive like your grandmother does, then the thinner ones will suffice
