Hey guys,
I made a list of the things I could remember that I csn sell on… If you need anything else let me know…
Sirion/cuore cv ends - $40 each delivered
Td04l-13t-6 with a steel wheel - EBay spec but comes with flow map and balance sheet - $300
Ej-de/ef-det turbo manifold. Tiny crack in it but it’s only on the surface, my tuner said it will be fine - -$100
QFM A1RM brake pads suit daihatsu cuore, good for 800 degrees on track temps, were custom made for me - $125
Brand new Lower control arms suit cuore/sirion hubs but fit onto L200, needed if you are doing 4x100 conversion - $100 the pair
Cuore front hubs, bearings are still good, again, easiest way to do do 4x100 conversion - $100 the pair
Redrilled rear L200 rear hubs to 4x100, wheel bearings in good nick, brake shoes probs need replacing - $100 the pair
Good condition bmc and brake booster from an L200. Mine were fucked so I got these online and got them rebuilt locally, so essentially brand new condition - $100
L700 cluster and surround, was gonna transplant into the Mira but never got around to it - $50
Standard exedy clutch suit EJ, brand new, fitted onto engine but never run - $150
EJ from an L700 and 5 speed box, box was inspected and all internals were good. Engine was compression tested when I picked it up and was very healthy - chasing $350 for the engine and $150 for the box, can ship Australia wide through my work for relatively cheap.
L200 tail lights with no cracks - $50 the pair
Fully refurbished L200 fuel tank, professionally cleaned and acid bathed then painted - $100
300lph E85 compatible fuel pump… Have wired it up to the Mira cradle but can seperate - $40 delivered
Alright that’s all I can think of for now… I also have a Mira shell sitting here so if people need random plastics or whatever message me and I’ll see what I got.
As mentioned above, I can ship basically anything Australia wide for relatively cheap through work, so if you need something let me know…
Thanks guys…
