As many of you know, I have been hoarding parts for some time.
I am making a list of all parts as I find them.
Rear wheel bearings
The same as L80/100/200/500/700.
Rear stub axles will take different hubs.
Backing plates are welded on.
Rear brake shoes for L55 / L60 is 180x36mm making them the same diameter as later brakes but with 4x110 pcd and wide shoes.
Early rear drums have 10mm wheel studs, late rear drums have 12mm wheel studs.
Early 10 inch wheels fit over 12mm wheel studs, I have confirmed fitment.
Wheel hub / centre bore is 66.1mm
Late model wheel studs are 12x1.5 mm
4 Speed gearbox ratio
1st 3.666
2nd 2.100
3rd 1.464
4th 0.971
R 3.529
Diff 4.736
5 Speed gearbox ratio
1st 3.666
2nd 2.100
3rd 1.464
4th 0.971
5th 0.795
R 3.529
Diff 5.081
This is from one source of the internet and I will do my best to cross reference for accuracy but the 4 speed information lines up with my printed chassis manual (with the exception of the final drive ratio which isn’t listed with the gear ratios).
L55/L60 with the AD engine has the dif ratio listed at 5.17:1
Speed 62 mph
Tyre diameter 19.09 inches (Falken fk07e tyre).
Late production AB and all AD mechanical water pumps.
1 Piece GMB High Performance Water Pump - GWD-26A Genuine Japan Brand | eBay Australia 1 Piece GMB High Performance Water Pump - GWD-26A Genuine Japan Brand | eBay Australia
