It’s been a little over a month since I finally bought my dream first car. I’ve learnt everything I know about cars from youtube video’s so naturally, I missed a lot of things when I first inspected the car. There were a few red flags anyway like misaligned bumpers, limited service history, car was running when i arrived, dealer said the car had 0 faults, It was owned by an old man so was stationary for a while, etc. But the car itself is a big green flag, it was very cheap and ‘only’ 160.000km, so how bad could it be?
Luckily, its not too bad! I wanted a well running car I could learn to work on, so in my case it probably is perfect. My first to do list consisted of the following items:
- Needs alignment
- Replace gear mechanism rubbers and bushings
- Clean the interior & Exterior
- Polish the headlights
- Replace right rear tyre
- Fix door lock
I’m still a student so my goal for the build is to make it look good and drive fun while keeping spending to a minimum and doing as much myself as I can. First task was to do an alignment, one of the tings I wasnt comfortable with trying myself.
I found a cheap place close by and also replaced my 10 year old rear tyre at the same time. Only the one tyre because I may want to change to 15 inch wheels in the future. The other three dont look like they’ve been driven much. The car drove much better after that. Steering felt lighter and fewer vibrations.
I planned a day of cosplaying car mechanics with my friends to tackle the remaining items on the to do list and added some more. The 4 of us all recently bought a cheap fun car to work on and make their own (suzuki wagon r+ not in frame around the corner)
Since none of us really knew what we were doing nothing went acording to plan but we all managed to drive home so we count it as a succesful day!
I ticked off sanding & polishing the headlights, servicing the car with new oil & sparkplugs, fixing the door lock by blasting everything with wd40, cleaning the oil that spilled all over my engine after losing the oil filler cap and spraying some rust spots in the rear arches with rust converter. Sadly there is a bit more rust than i initially saw when I bought the car…
It looks like the rust is limited to this area in front of the right rear wheel arch. The parts around it were still solid. But I know I must do something to prevent it from spreading. I can’t weld (Yet!) so i’m hoping its not too bad?
That’s where the thread ends for now. I was hoping to do the gear mechanism rubbers but my friend took all day to fix the breaks and we only have 1 set of axle stands. I’m also in the proces of buying 2 sets of speakers but the seller doesn’t seem to be interested in selling so hopefully they’ll have arrived by then too.
More updates to come!
