Daihatsu Sirion M111 1.3 4x4 top speed
Hello there,
Does anyone know what is the top speed of Sirion M111 1.3 4x4 with K3-VE2 and manual gear box.
Thank you in advance.
I believe its about 110mph/175kph. The factory info on the 2wd Rally 2 is that it tops out at 114mph and that has a bit more power and a bit less weight so I’d expect it to be (fractionally) faster than a regular 1.3 with 4WD.
I also suspect its utterly terrifying at VMAX!
