Hi all is it posible to put my automatic transmission on a ejde.
Because i want to swap to a ejde only i want to keep the automatic.
Thank you all for reading.
should be fine to fit. If it were me I would be getting a sirion auto to go on it too.
If what you mean by a “sirion auto” the 4-speed automatic, it would better suit the EJ’s power band than the 3-speed
And that is the M100 Siron, if I’m not mistaken?
I find this information interesting; the only thing I’m dreading a bit is modifying the driveshaft, but that should work out fine.
I’m not sure about the second generation Sirion series. But the 4-speed automatics from the Mira/Cuore series should fit without modifications, I was told
That would be you your positive in keeping your current auto is you don’t have to modify the driveshafts.
yes that is what I mean. I stated sirion as I wasn’t sure what autos are in the cuore (L7). Well not even sure what we got in them in here in AU.
