Efdet electrical
I have decided to start playing around with the efet I have and thought i would post here first as i may get a little more response here. (maybe) Does anyone have a pinout for the efdet ecu. ( I have looked in the manuals section) Its engine loom plug is the same as an early ejde plug but it doesn’t have the 2nd plug that the ejde uses in it’s loom. (ejde loom does plug in) The loom also has a green plug but It does not plug into the ecu. the No. 3 socket on the ecu has no pins whatsoever.
Here are some pics to show what I mean.
I think I have it sorted.
time will tell
Hey man, how did you go with the ecu?
I bought the same ecu n looking for the pin out diagram
I have ejde that i want to use this ecu for turbo charging it
Hoping you could help
that ecu will plug into the ejde loom no problem. I wont say it will be fine but in order to get the ecu running I had to wire some power to the little green plug. It was about a year ago and cant remember what I idi but it should not be to hard to be honest.
Thanks man…
Im pretty sure the green plug is not plugged in in my cuore atm
Im bout to open up the ecu n take pic for future reference
