I’ve removed my valve (rocker) cover and cleaned it using a pressure washer but ended up blowing out one of the Spark Plug Tube Seals.
I’ve seen another thread on here suggesting a very crude way to replace the Spark Plug Tube Seals on the EJ-DE by bending the baffle plate using a screwdriver and hammering it back, but I wasn’t able to force myself to do something so ham-fisted so I enlisted the help of my ex-airplane mechanic father-in-law to make the baffle plate removable.
The valve cover on the EJ-DE uses insert molding to attach the baffle plate to the cover. You can see the rivet-like shapes on the baffle plate. These are not rivets but are pushed through the baffle plate holes when the cover is casted saving material and manufacturing cost.
The steps included:
Drilling out the rivet-like shapes to detach the baffle plate using a large drill bit and knocking the remaining material off using a chisel.
Removing the baffle plate and cleaning the cavity underneath.
Drilling 3mm holes where the rivet-like shapes used to be.
Tapping each hole to M4 size.
Adding ‘Gasket Maker’ to the veins between the cover cavity and baffle plate.
Attaching the baffle plate using M4 screws & washers with lock tight.
