Will be the first time doing the timing belt and water pump replacement, any tips on how to get the timing belt tension right? And what is the torque for the camshaft pulley? The manual only show the torque for the water pump and crankshaft pulley.
about 90nm or so for the cam pulley, and use a big flat bladed screw driver for tension while doing up the adjuster
