Alrightyyyyyyy. Posted my intro, Hopefully a few more peeps know me now.
Ill try and keep a build thread. But no promises, it may just appear finished
who knows.
So all cars, L200 , 2 door. rear seats, all had 660cc and manuals.
- My old daily. will probs only use the bride out of this/rear trxx seats. rest is pretty standard.
- The pretty shell. Again not much, Trxx interior pieces. Bits and bobs, new wheel bearings ect.
- The New one! just got home from buying and picking up the new Hatsu! i am probs the only person to spend more than 2grand on it. but here is the short run down on what it has(more to follow as i find it/add it)
New steering rack
Custom Sub frame bushings
New bushings throughout
New engine mounts
Re-painted and welded/repaired subframe with fish oil through it
Removed surface rust and repainted drivers from wheel arch area
EJDE with 98k on it
Machined Flywheel and new clutch + throwout bearing
New rear main seal
New diff side seal
new/re-cond CV joints
New tie-rod ends
Old lower arms & new ones (forget if I installed them or not!)
HWL coil overs, front strut brace + rear anti roll brace
New brake master cylinder
Included new parts:
New handbrake cable
New clutch cable
Accelerator cable (I think?)
All fittings and lines to connect to new Aeromotive FPR
Tachometer for 3 banger
Stainless braided brake lines (fitted but not secured fully)
Gasket kit
Dodgey Malaysian extractors (look pretty but they might be rubbish honestly. $350 wasted potentially)
2" Stainless exhaust.
Other fruit:
13" 4x110 SSR MK3โs full set, with correct wheel nuts and stainless replacement rim bolts all sourced from J-pan (the wheels themselves will need the centres machined out a tiny bit to accept the hubs for some reason.)
13" 4x110 restored Mazda 4 spoke items with ok rubber. I think 2 have mint rubber on them from memory.
So hopefully with all these 3 together ill have a fun streeter with little to no problems
and hopefully the pictures work.
The old 3 that i had. parts used from the first 2.
Sneaky pic of the new set up! Will post some more photos as i go/hopefully. But keen to keep it simple on the outside!
https://imgur.com/gallery/xukkB
also added is the 13" Ssr Mark 3s
Still havent washed it properly. Waiting for the right time. Black carpet will be cleaned soon, Trxx rear seats put in and the Trxx Handbrake/shifter surround is to go in soon. Slowly getting there.
