For the rear with suspension, a cheap ( for Australia) is Hyundai x2 rear shocks with the crush tube cut flat to fit. They make the rear a lot stiffer than stock. I would have thought 165/55/14’s would have been fine
They where fine on the other wheels, et is different.
Well ,makes a good excuse for rear camber.
The hub is fixed on the axle, so it’s not possible to take it off and put shims in between. The only option would be to take the hub off with a grinder, which isn’t ideal
Well, challenge accepted!
I do have a spare axle
I actually didn’t know that…
from which hyundai do you use the rear shocks, like to try it sometime.
nice care by the way
Hyundai x2 aparently
Googled it and should be a Hyundai Pony here.
I know its eBay Australia in the link but ones like this
ok thanks ill no longer hijack your topic
