Ej-ve n/a build
Planning:
K3 pistons
Fully flowed head
Short ratio gearbox
Custom intake
Exhaust
Tune (eventually)
Bought:
Full gasket set inc.valve seals
K3 pistons (188€)
Shims
Liquid gasket
Sparkplugs
Valve paste
Exhaust manifold
Done:
No
Donor head, looks pretty good for. 140k.
Port match, flowing and refurbed valves
Guy who did the head said it was one off the worst flowing heads he ever seen.
Mind you, he is used to motorbikes.
Anyways, slowly but surely…
Out with the old etc .
Difference between ej and k3 pistons
Very cool to see, I am interested to see how this turns out :slight_smile:
Thanks for documenting as you go!
Pressed(!) Out the pins and pressed in the new.
Never had to do that before, normally piston pins are held in place with clips, but there you go.
Ej rods did NOT fit the k3 pistons .
Had to make room to give extra play.
Milled down the inside of the pistons a bit.
Hope i gave it enough , will see with install.
They look really well made…
That is what I wanted to do but I gave the pistons away years ago when I never had an ejde and now I have one and the piston’s went awol lol. It is a good engine anyway so I don’t want to pull it apart yet lol Maybe in future
Clearance measured on crank and rods, all within spec, so assembly is next .
Had the head inspected by specialist and they’re doing a valve seat adjustment where needed.
Meanwhile doing some bodywork on the Cuore.
Might still have a set. Found some about that size. Foggy memory. Found a solid Dai
puck clutch too. Will put aside for you.
thankyou sir
Awaiting the cilinderhead…
Bodywork somewhat finished
Needs a good polish.
Paintcode RAL 3020 signal red, but looks very orange
Meh, was cheap.
Wheels are Renault Twingo mk1.
Big boi!!
Nos rear bumper without cut outs for towing or mistlight.
Test drive was not great.
Et is completely off.
Tyre rubs really bad on the rear wheel arch, with standard springs.
Tyres are Yokohama blue earth 165/55/14.
Was planning on doing sirion front arms and axles in the future and build diy rear beam.
Might just try camber shims in the rear for now and hope it works.
Any suspension advice is appreciated.
