Does anyone have a diagram for L200 EF-JL for the emissions control?
I wanted to replace all the vac lines, and set it up correctly.
This is how it is set up, upon removal of the hose for the map sensor I have a T peice which goes into the intake manifold at the front underneath everything. No fuel lines going to the charcoal canister either. The rocker cover breather hose isn’t hooked up to anything either, just a hose hanging down.
Also I am having a intermittent missifre on idle when cold and hot.
There is another issue I am having where it wont idle mostly when its hot or on a hot day. Like it revs and drives fine, justy wont hold idle, it stalls straight away.
Anyone have any ideas?
Does anyone know what spark plugs fit? I might do those while I’m at it too.
