engine oil dip stick for sirion 1.3 ,as the old plastic thing broke .looking for a steel one . or measurements from the bottom of the stick to the full mark.
Thanks
Hughie
I would try a wreckers.
https://www.daihatsu-drivers.uk/node/17528
My Rally 4 measures just over 500mm from seat to end of dipstick
SCA has some with the tubes;
phoned wreckers ,same problem all gone or broken ,trouble is the end is in the sump. will make my own ,what i really want to know is the distance from the bottom of the stick to the full level hole. if i can get that will be easy to work out the rest, so any help with the measurement would be great.
Regards
hughie
That it the critical measure, it is the K3-VE?
There is this generic unit but zero detail;
https://www.onlinecarparts.co.uk/spare-parts/daihatsu/oil-dipstick/bd-m3.html
Thanks for that Paul ,like you say no detail and it looks like its the outo transmission . But not to worry some kind soul might measure there dip stick for me.
nice talking
I ll measure it up for you. I have the k3ve2, not sure if theres a difference.
Scale is in CM ofcourse.
Absolutely brilliant thank you very much ,now i can make up a steel one.I see you have one of those crappy plastic ones as i had ,old age and heat made it fall to bits. any way big thank you for your troubles . nice talking to you.
regards
Hughie
Show us your finished product!
You could possibly grab a metal one from SCA and then trim and mark (scour) to match the length (fill mark specifically).
Awesome response @Roffelkut
Funny you should say that ,my mind was working on that idea,will see how i go ,should be easy enough.
thanks for helping.
will do that ,because if any body else needs to do this it will all be available to see .
thanks for showing an interest.
