I replaced the belt with the timing marks aligned done the two rotations and the belt marks lined up (should this reassure me the timing is correct) but with all lines and connections fitted I can not get it to start it just keeps turning over but if I pump the accelerator it cranks faster (as if it’s going to start). Can anyone give me a few other areas to look (currently checking electrics). Cheers
tried that " Start Ya Bastard"? or a little fuel down carb? i found my g11 takes a fair while to pump fuel up with the mechanical pump
Distributor plugged in? I found out the hard way after looking at everything then realised i’d forgot to plug it in lol.
