G200 gearbox
Hello I need help with finding out difference between applause and the charade gearboxes. I mostly want to know is there much of a difference between the diff’s and also how to know which cv’s I need. I heard there is 3 different types on the g200?
Thank you
The ratios are different between them and so are the amount of teeth on the driveshafts. From memory there’s one tooth difference between them for a G200. A G102 may be the same as an applause though but i havn’t checked.
Do a search under “Grog” - there a section in the post that has the ratios for all the Charades and the Applause. The driveshafts in the HD gearboxes are apparently different spline size, it pays to check.
Okay sweet thanks for that!
