Gtvi wing on non gtvi?
Has any one successfully but a sirion gtvi wing on to a non gtvi? Is it a easy job where the holes are there and you just have to line it up or is it more involved?
Here is a pic of the holes on the gtvi rear hatch. B91133F0-2317-4686-B01B-917F54F64070
Awesome thank you. I’ll have a look on mine and see if they are there
I don’t think they will be there
Those holes are only in the hatch with the wing. I have both here and there not there in the non wing hatch.
Ahh bummer. Was hopping they used the same tooling at the factory and just didn’t punch the holes in the outside skin.
Man just mark it out and drill it thru.
You can buy bungs / grommets at Bunnings but buy them first so you know what size hole u need.
Also use some sikaflex to seal the holes for bolts and wiring for light off and a few spots to hold it.
The sikaflex will stick it harder than :poop: To a blanket.
