HD-E problems
Hey guys new member here,
So long story short I got a f300 Daihatsu Feroza a few months ago the guy I got it off blew the motor and quickly swapped a applause HD-E into it
Now when I bought the car the swap job was not the best all the vacuum lines where wrong sensors not fully plugged in and what not seller even sold it as needs to be trailered
I drove it home stopped around the corner from his as it was extremely smoky and fumey and corrected the vac lines and plugged in correctly the sensors I found this fixed a lot of the smokiness and fumes but however another problem has lingered
Motor idles good but when u hit the throttle to rev up she just Boggs down and dies you can drive through it by extremely gently revving it to about 3k rpm then will rev through and drive fine
I have since found the intake manifold missing bolts and bad gaskets rocker cover bad gasket exhaust manifold bad gasket all have been replace have removed disassembled cleaned out and inspected dizzy have replaced intake pressure sensor fuel pressure reg all spark plugs done a compression test this is all good too just a little stumped it has good fuel pressure and when it Boggs down it smells very rich and puffs black smoke then dies like it’s getting too much fuel?
is the vaccum for the map sensor good? is the tps hooked up? o2 sensor maybe? all of these help the ecu with fueling.
New tps and harness plug to it new o2 sensor and replaced the map sensor in manifold plenum also have a second idle up and whatever the other vac sensor on that mount I’ve tested with
