Hello! Thanks for the inclusive nature of this community. Neat idea. I’ve purchased a cheap CX Charade (1.3l HC) still running fine but with a blown head gasket. it’s in lovely condition and sitting at 100,000k’s, so I felt it was worth saving it from the wreckers.
hopefully there’s some info kicking around, maybe a workshop manual. Thanks, happy tinkering
I’ll start a new thread regarding the project if anyones interested.
I’m going to check the oil cooler behind the oil filter for damage before looking at the gasket as there was a significant amount of oil in the coolant, but no coolant in the oil. There’s no over heating or smoke in a 20-30 min test drive and the car idles and seems otherwise fine.
There’s no visible bubbles when the radiator cap is removed. Occasionally I’ve seen a few bubbles in the expansion tank, but don’t want to jump to conclusions as I changed the coolant to get rid of the oil so maybe there was still some air bubbles after topping up and burping.
Or is it normal to see a few small bubbles in the expansion tank in these cars? Especially after changing the coolant?
Hi mate these motors are particularly bad for having air in the cooling system after a coolant change. A few bubbles wouldn’t concern me in the expansion tank. Maybe even try giving it another bleed.
