I’m trying to figure out the abreviations. Most make sense, except the PMNT and E/G in the second column.
If you know what they are please post and let me know.
If I could only place that image under a microscope
If you could post the specific year of that Hijet’s fuse box , I could then compare it with one fitted for Europe and then identify which fuse is represented, based on its location. Here is what one supposedly for a Hijet looks like:
It is a 96 s110P
from another daihatsu manual, E/G means Engine
and PMNT means Permanent. possibly constant 12v power?
When in doubt, simply pull each unidentified fuse and then see what happens or doesen’t happen
