Ho dethe engine start-up problems at the Sirion m100 year 1998
and I wanted to start from the fuel pump to see if it passes gasoline but unfortunately I didn’t find the passage to access the pump. I ask : do I have to disassemble the gasoline tank?
Thank you
You should be able to hear the pump prime when you start the car (one click before strting) in not undo the fuel line in the engine bay put it in a container and turn the key to on position. If you get fuel coming out your fuel pump is working. if not then it is in the fuel tank and will need replacement. Please note the fuel pressure coming out of the fuel line will be at about 45psi. So best to have a 2nd person helping if you can. One to turn the key and one to hold the line and container.
Thanks, the pump is heard turning for 4 seconds I set in motion, turn the starter but do not start the pistons. I’ll try as you say. But is the petrol pump accessible without disassembling the tank?
no the pump is in the tank. Is the engine cranking?
I ask because from what you have said it sounds like a flat battery.
[quote=“evilhighway, post:4, topic:7732, full:true”]
[/quotegood morning, no the battery is charged and the fuel pump stops on its own.
then I carry the key on ignition and the starter runs but does not set in motion anything.
[quote=“evilhighw railay, post:4, topic:7732”]
[/quote] sorry evilhighway, you say that the petrol pump is inside the tank I know but to access and inspect it I have a door to open without disassembling the tank?
no you need to remove the tank.
