Hello everyone! I have Daihatsu Sirion 2004 1.3 at
Mileage 239k km
Yesterday i replaced an intake gasket and notice that
the vacuum sensor has no connection with a pipe(also im not sure that it should be, because i don’t really understand what is this sensor for)
Also the main problem is misfiring in random cylinders. p0300, p0301, p0304.
sparks new, swapping coils did not make any difference
intake gasket replacement didnt help too.
I’ll take a look tomorrow where that line should go. Have had the same issues when one of the vacuum lines had a crack in them. Should be just a simple case of fitting the correct hose to fix your problems
Hello, Just to let you know you can speak in your language and the forum has a translate button we can click on to translate form your language you English.
One other thing is if you could go to the “all new people” section and do a small introduction. Just be sure to click the new topic button on the top right and make an introduction post. It doesn’t have to be much it just helps open more of the forum for you.
I will provide links and a pic below.
I’ve tried to locate it but i have the K3-VE. On my engine it seems that are 2 tubes. One goes to the charcoal canister and one goes to the intake. But it looks different from what you have.
I would suggest you look at the parts you took off and check if there is somewhere a hose could be attached to. One vacuum hose from my airbox had a crack in it which caused a misfire in 2 cilinders.
Thanks a lot for your response!
I think my car just miss the second hose which goes to the adsorber.
According to the scheme it is just a regular hose right?
