Hi dose anyone know if the l200 660cc turbo ecu and loom will work on a na 660cc with a turbo fitted.
As in are injectors, coil ect the same
series 2 ecu plugs are different. I had a series one wiring loom run a ef jl turbo ecu but it didnt run as well N/A and didnt bother playing with it more.
Have you checked plugs to know which series ecu you have? If the plugs physically fit then you would have a series 1. You will also need to see if all pinout’s are the same also or if your missing some and what they are if you are missing them.
