L201 Bulb sizes
My instrument cluster backlight seems a bit dim, so I’m thinking of replacing them with newer brighter LED filament bulbs. I’ve taken everything out to have a look, but I’m not sure what size I’d need to order. I’m probably going to replace the air conditioning control bulb as well.
Would anyone happen to know what sizes these are?
Instrument cluster bulb:
AC controls bulb
instrument cluster is t10 bulbs air con t5
You probably know but just in case anyone out there does not know LEDs are light emitting diodes. Diodes only work one way. If you put it in and it does not work, flip it around.
As a temp fix pull off the green plastic cover on the std bulb.
