i’ve been plucking away on my l210 4wd with efel and unfortunately i didnt have the foresight to mark or take pictures of my vacuum lines and i have a couple of plugs that i’m missing a home for. I have a couple of books that have been somewhat helpful in getting some direction but the vac and wiring diagrams that ive found (both in those books and online) dont have the 4wd model. I’m hoping someone has either the experience or maybe access to a diagram that they can share with me, or maybe you have an l210 and can take a peek at your setup.
first plug im confused about is this green guy, comes off the harness heading toward the distrubutor. there is another green plug on that harness that reaches and plugs into the dizzy so its not that. hanging loose is hovers above the starter
second is this spade connector, chillin under the dizzy. maybe its just a ground and i can find somewhere to stab it but i dunno
on the vacuum side of things, there is this banana(???) shaped metal cylinder that is attached to a bracket on the transfer case and it has spots for vacuum lines on the top and bottom of it. in the diagram below it is item 75, you can see the vac line coming out of the top but not the bottom from that angle. my best guess is the bottom goes to the vent that comes off the middle of the transfer case (part 87 in the diagram) but there is a chance it goes to the diaphragm for the 4wd switch. but if its for 87 then i dont know where the top end would go? unless its just meant to vent to atmosphere at the top if its for part 87
here is a photo from above where you can sort of see it as well and you can also see my fourth conundrum. there is a broken vent on the transmission just up and to the right of the clutch arm in the photo, i forget if it had a line that went somewhere or if it was just a vent?
any knowledge i could borrow would be incredibly helpful, thank you
