L7 Bogging down under heavy throttle
Hello guys, so my 1.0 L7 hesitates alot with heavy throttle. It doesn’t do it sat still. Seems to be under load. If I’m going say 30mph and I floor it it really bogs down. I’ve checked for vacuum leaks, bought a coil pack and changed them over, new plugs, cleaned the throttle body with carb cleaner, does anyone have any suggestions? I’ve definitely got a rear engine mount thats bad but other than that I don’t know what to try.
Is there a difference between high and low rpm?
I think it seems to be more at lower rpm
It might be a bad igniter or more coilpacks, bad ground on the igniter could also cause trouble. Does the car blow smoke?
No smoke at all. I did try coil packs. I will check the ground, thank you
