Hi guys, I’ve been scouring across the internet but every manual I find for the L7 has information in regards to the sirion’s EJ, and not the L7, there’s a few wires that are different, and they happen to be amongst the ones I’m trying to work on.
Does anyone either A: have the L7’s engine mechanical workshop, or B: have any sources regarding the L7’s full ignition wiring diagram?
Thank you!
Have you tried out manual section? I belive there is a manual in there for the L700.
If it’s the one uploaded from Niko then yep, same manual that I’ve already come across, incorrect diagrams
Unable to open file
What is it your trying to do? That may help with getting the help you need. I downloaded @nvergaraa’s file that he posted here and it works fine if you open it with a zip program. (on pc) If you are on a phone then no idea. I think it is the same ones in the manual section.
@nvergaraa I am deleting your post with the file link in it as we try to keep manuals to the manual section. (just letting you know)
No problem… deleted
Ohh okay, also I’m just trying to find the ignition loom under the dash, I was told a while ago the wire color that I’m trying to find, but when I looked, there was multiple looms with the same color (forgot which one it is, it’s in a text message somewhere) but yeah I just need to find that whole loom basically
