L701 burning oil only in cyl 1
Hello all,
I am helping a friend who bought a L701 that burns oil only in cyl 1. It has 123500km and history unknown. For project is this car
Compression test
Cyl 1 - 14bar
Cyl 2 - 14.5bar
Cyl 3 - 14.5 bar
Now a few possibilities before starting throwing parts/ rebuilding this ej-de
Could the headgasket been blown and seeps oil to the conbustion chamber?
The oil dipstick hole when its hot the hole blows white smoke.
Engine does stay in normal temp no overheating
Any suggestions is welcome
valves or rings in cylinder 1 could also be a possibility?
maybe how to test?
without disassembly I am not sure
What makes you think it is burning oil in cyl #1?
I took all plugs out and only 1 is oil present on the spark plug. other 2 are no oil present
With compression so equal: I’d not jump to headgasket failure or broken rings too quickly. Dud valve stem seals maybe. Easy to do in the car without pulling the head with a couple of special tools and an air compressor. Check PCV for being blocked (you say white gas out of dipstick hole, does the same come from the oil fill hole?). What you see are crank case gases, too much pressure inside pushes oil past things, in a perfect world you’d want to pull a vacuum on the inside so not pressure (go to comment about PCV and add “look at crank vent hose” that goes to tappet cover). Oil level not too high? Does it missfire?
ok will check that. no misfire but, it fouls the spark plug
normally valve seals bad only smokes in the morning?
there is no gas coming out of the oil cap.
Looks like hose from pcv is not much air coming out will clean that also
Crank case needs to be venting. Check line from block to tappet cover is free flowing. Combustion always gets past the rings to make pressure the sump. Crank swings about splashing oil which mixes with combustion gases. To much pressure can mean some escaping back up via the rings as the piston rises. PCV should only draw combustion gases a idle when the engine is pulling vacuum.
Are you sure that spark plug is firing properly? Swap it. Does it have ignition leads of coil packs? Check these.
it fires fine after spark plug change but, cyl 1 still gets oily
I’d go for a #1 cyl inlet valve oil seal change. Can be done without removing head. I’m a bit tired to explain right now. Have a google and see what you find?
Ok lets try that first. Otherwise I have to remove the engine and get it refurbished if it is the oil control rings
Concerning rings, could be a broken compression ring too. Do you have a cheap borescope camera? Stick it down the bore and look for scratches.
In a pinch when I could not lift the engine out (engine and box together easiest) and only had the weekend before I had to drive it to work, pulled the head jacked the car/put on stands, removed the centre brace and pulled the sump. Covered the crank. The blocks are soft so 2-3 strokes with a three pad 220 hone (DO NOT USE A DINGLE BALL HONE) and 3-4 strokes with a 400 grit. Oil will sit in the 220 grooves and the 400 will just fix the edges of the 220. Oil sits in the 220 just enough to lube the compression rings. Cover the crank not only to stop rubbish but in case you hit it. Put a rag over the stones at first and practice at drill’s lowest speed. I use an air drill for super slow and best control. 45deg hatch. More passes more oil up. Less can cause ring chatter. Super clean with paper towel and not rag. Use assembly lube. If you want cheap mineral oil with absolutely no friction modifies. Dump the oil fairly soon and replace with run in oil (mineral only no friction modifiers or detergents). Drive neither on light or full throttle. Step hill is best and hold it at max torque or load it up driving on the brakes. You want max combustion pressure to push the compression rings outward. They will form most of their pattern for best seal in 20-40km. Keep some load on a few hundred k. Put good oil in.
Put some new plugs in. The orange around the bottom of the porcelain looks like they are burnt out. I don’t think that is oil on the plug. It’s carbon build up from not firing. New plugs ASAP.
I installed already. Its getting less smoke now. Only at cold its a lot
Its smoking less. I blew some air into the pcv with high pressure and it seems to be declogged now.
Lets see. almost no smoke now.
I also drive it above 4k rpm the whole day when the car is moving keep the.engine oil temp hotter. This was probably a short trip car
I drive it warm now (10km) and floor it all the day. I get 1:16 average flooring. 750km now engine oil level is same.
I have installed NGK BKR5EIX-11 now so I can leave them longer in the car without a check. Will open every 5k to have a look how clean it is.
I guess cylinder wash with short trips
