In all honesty it’s not the best looking F300 around, but it’s technically in great shape.
It has VERY little rust and i rarely hear an engine run this good.
There are a fair amount of dings and dents and scratsches. But i don’t mind.
Gonna pick it up tomorrow.
I’ll be using it mostly for what it’s made for… OFF-ROADING!!!
So the plans are…
Winch bumper
A winch of course
LED light bar
Maybe a set of decent off-road tyres
Maybe lift it a bit higher (it’s already a bit lifted)
Either paint it army green or in bed-liner
There’ll probably be more, but this is what my plans are at the moment.
Been trying to install the winch mount, but it didn’t turn out the way i wanted.
It feels very flimsy and weak. Even though i can jump om it, i feel like it’ll rip right off when i’ll be putting a little load on it while winching.
So i’ll be looking for a different way to mount the winch.
If anyone knows where i can get a decent and cheap winch bumper or know a proper way of mounting it (without to much hassle, PLEASE let me know!
Pics will come later. I’m to tired to upload them to my pc right now.
you can upload pics directly from your smartphone, use the upload button in the bottom right corner when your writing a post.
I would imagine with a welder and a bit of elbow grease you should be able the build a winch mount quite easily that bolts the the chassis rails. Have a look on google images for some ideas, otherwise im sure something could be sourced from TJM or opposite lock
After a long and tiring week I finally got the chance to work on my feroza.
I got it all made to fit and welded and bolted on.
Now I’m about to mock up the stainless steel snorkel I’ll be making.
If any pics are switched I’ll put them back in order if I don’t forget (again).
I bend the rear bumper a little. I think it was in this hole.
You might not expect it, but it was very deep and steep. (One of the times i stressed the winch a bit).
I would look at fabricating a kind of tubular bullbar with winch mounts integrated into it, would solve the issue of a front bar and strong winch mounts in one hit. Also you could knock up a snorkel from some intercooler pipe pretty easily and cheaply, and they look pretty good in my opinion.
I think something similar to this could be achieved with basic tools and materials, and a bit of know-how
