Still having a low idle issue, idles down to about 500 rpm in D
Cant find a vacumn leak anywhere
Removing coil leads doesn’t show a weak cylinder
Swapped out map o2’s and coolant temp sensor
Cleaned tb and replaced iacv
Seemingly drives completely fine with no noticeable miss, does have a hiccup now and then at idle
Igniter maybe?
