Finally have time to sit down and do my build post
As most who already know LSP would know, I didn’t do hardly any of this work myself. I paid mechanics, tuners, auto electricians, spray painters, friends, etc., to do the work.
Basically the build idea was to remove the original EJ DE engine and replace with a K3VE2 engine (Sirion GTvi), that had been bored out to 1.5L and add a turbo.
It is also dual fuel: P98/E85 and dual tune: 12psi daily and 15.5psi track.
1919385_10153128401395947_3539586224467901161_n|275x500
1934247_1106225012729866_532791614562435037_n|292x500!
1934552_1106225712729796_7146760601576712303_n|292x500!
10455336_10153073705040947_8951351689860105394_n|690x388
12376017_1106224996063201_1425966485829319945_n|690x403
12527936_10153298090785947_1148620635_n|292x500
12980525_10153342345735947_166166624_n|281x500!
12988154_10153350738865947_2055984118_n|281x500!
13089999_10153380560310947_468396171_n|281x500!
13090068_10153380577135947_1213849527_n|281x500!
13090272_1195410123811354_1744783988_n|666x500!
13101050_10153380560170947_1099585292_n|281x500!
13115598_10153380560125947_870432188_n|690x388!
13112562_1192148357470864_308822176_o|690x388
No room for this in the engine bay. But sadly the G forces under braking mean, means that the reservoir is usually empty. I need some genius to work out valves or something, so that the water only releases when the pump is activated…
