Hey legends wondering if someone can help me I need a sump gasket for my sirion m100 I have just done the crank oil seal today thinking that was leaking but no it seems the sump gasket is leaking. Does anyone have any contacts or idea where I can get a gasket in Australia tried google and no good
Hopefully someone can help me get this back on the road
Weren’t these oil pans glued on using silicone at factory assembly?
these don’t have sump gaskets factory, only sealant. You can make one from gasket paper that you can buy at any auto store, but id personally use a handmade gasket and some sealant.
Thanks all I will rip the sump off today and see how I go
[quote=“ceiliee, post:4, topic:7031”]…You can make one from gasket paper that you can buy at any auto store…[/quote]I glued mine years ago, using silicone, and it’s still holding bone dry. It’s important to first completely degrease both surfaces
Thanks all I have had the sump off today and replaced the sealant but still leaking, I have now done the crank seal and the sump is there any other place on the timing side of the motor which is prone to leaking or do I just burn it??
rare but did you check the oil pump? where it seals to the engine block?
Didn’t check that but looks like i will be pulling that out and looking, is it safe to use sealant on it as I can’t find a gasket
should be fine. I have used sealant in the past.
