M300 sirion exhaust
ok that sucks:). Guess going OEM is the only way then. Thank you for replying.
No problem. Unfortunately i came to the same conclusion. Pro tip, use a long screwdriver and some wd40 to get the rubber exhaust hangers off. You’ll need to jack up the car both front and rear to get the exhaust over the rear axle. I usually jack up the front and put it on jackstands and work my way back. You should be able to leave the shock absorber attached on the rear axle and push the exhaust over with some force.
I used aygo parts. They fit, but mine is a 3 cyl engine.
