My YRV project car
Hello! I am so glad to have stumbled across such a treasure trove of information and enthusiasm!
Back in March of 2017, I travelled to London and picked up this 2004 YRV 4Trak, and drove it home (via a stop over at my brother’s house in Surrey) to Aberdeen.
Initial issues identified in those two days:
  1. A horrific rattle when the clutch was out
  2. Broken CV joint boot (which we managed to replace - on a weekend no less!)
  3. It jumped out of 5th
  4. The speakers are absolutely dreadful
Sadly, it was slightly larger than my garage at the time could comfortably hold and be worked on, so work was exceedingly slow. Despite the slowness, I dropped the subframe so I could remove the gearbox and change the clutch. This was the state of the old one
And the flywheel looked the worse for wear
And while I had the subframe off, I might as well de-rust it:
It was about this time that I moved house into a place with a more comfortably-sized garage, where I could work with the garage door closed (and thus, not quite so damp/cold/windy). So I reassembled it, and took it to it’s new home (about September of 2018).
Now it could go up on axle stands, and I borrowed an engine crane to take the engine out. I also removed the front suspension completely, and have serviced the calipers. Here is a before picture:
Annoyingly, my vehicle has “Akebono” brake calipers, and to service them, I had to buy three different servicing packs in order to get all the seals and rubber boots! They are all reassembled - if I remember I will post pictures.
With the engine out, I stripped it down - mostly for my own education. It is a K3-VE engine, and what a marvel they are. So compact!
Here is an artistic photo of the Variable Valve timing actuator:
All the running surfaces on the cams were beautiful - practically no sign of wear on a no-service-history 80,000 mile engine.
Are people interested in seeing the awful dirty cruddy pictures? If so, let me know! I have cleaned and painted some of the exterior engine parts. I managed to find timing chain, gasket and bearing kits to refurbish the engine (more on this later).
This is still in the strip-down phase:
Underside of the head:
These are the parts from the stripped-down head.
Rotating assembly removed from the block:
I have access to a fairly well stocked Quality Control department and all their measuring equipment. Everything is well within specification (I got hold of the Daihatsu Service manual - very comprehensive!).
With the help of a friend, I disassembled the pistons from the rods, then cleaned them up:
But it wasn’t long after this that my project grew yet another limb, and the decision to try and turbocharge the engine was made. So I bought some 3SZ Toyota pistons, which will lower the compression ratio a touch.
I also started removeing more of the front end to make access easier … and discovered some rusty spots, and broke a great many seized bolts, even breaking off some captive nuts.
I turned my attention to the front hubs. Oh dear. The brake shields were more like lace shields!
Not sure what to do about that - no sign of a way to find new replacement. Current thought is to try and fab something myself.
I made a foray into electrolysis as a method of removing rust from odd-shaped things:
I may have to try my hand at zinc plating. Does anyone know how critical it is to have removed all the rust before plating?!
Oh, have I mentioned how many CV joints I have had to buy, then mix-and-match them in order to refurbish my front axles? Not shown in this picture: the ones actually fitted to the axles.
Here is the turbo I plan to fit, how cute is that! It’s adorably small. Also in shot, some of the repainted cross-members taken off the front.
Here’s a picture of miscellaneous bits. Old wheel bearings, new springs and shocks, a fog light switch for my intended fitting of fog lights to the front, an assortment of hub nuts, brake pads, water pump…
Here is the current state of the interior…
Stupidly, I also set about repairing and repainting the front bumper. I don’t know why I started this, since I do not have any colour-matched body paint, just generic “red” paint! Ah, well, who needs colour-matched panels?
While digging through my boxes of things, getting sort-of ready to start reassembling things, I came across the front engine mount. It has a ruddy great split in it:
So I have pressed it out, and plan to mould a new one out of Polyurethane. Trying to find a new one was a complete non-starter. The other two mounts seem just fine - thank goodness!
The reason I started putting this post together is because something of a turning point is being reached. I finally got around to sending things off to an engine machine shop to get the block decked, valve seats cut in the head and the flywheel skimmed.
I have done test reassembles of the head, and placed the order via Amayama for the correctly sized cam buckets. The valve seat machining removed between 0.06 and 0.1 mm, so I needed much smaller cam bucket sizes. Plus the extra heat from potentially turbocharging the system, I am aiming for the larger end of the allowable valve clearance to the cams.
Things I have not mentioned: Buying a second gearbox via ebay. Fixing the rear wiper,sourcing missing interior trim pieces, fixing the back door catch and handle, and the fact I may have broken the number plate lights. Deciding to get an after-market ECU. Me procrastinating about getting decent speakers (my sister has given me a decent head unit). Me buying some cheap second-hand intercoolers from ebay to see where I can fit one without having a mess of pipes. Oh. One thing I shall mention: on removing the side skirts…
I’m going to have to learn how to weld.
That brings you up to date. I hope it has been an interesting read for you guys. Just remember that this one post condenses two and a half years of … procrastination. I’m hoping that having some interested people following along that I will be encouraged to keep the project moving forward. Thanks to all of you for the inspiration!
Fantastic write up. Thanks for adding the treasure of info.
I’d remove all rust before zinc plating by hitting it with acid. Muriatic if jusit a bit of colouring, but I go first with hydrochloric if it is really bad (you’ll get light red/orange rust after).
wow this is fantastic and a great wealth of info for me as I have a red yrv that I got a few months ago. Mine is certainly for just daily cheap runabout duties (also fwd). the toyota 3sz pistons are they direct replacement or do you need to go up in size? Not looking at turboing mine but you nevere know haha.
Awesome right up and it is always interesting reading those with technical training detail their projects. I have to say I love the methodical approach with the parts from the stripped down head in that compartmentalized toolbox and bagged etc. Keen to read and see more.
They are direct replacements. People also use K3 pistons in the 3SZ to get extra compression for NA engines, too. Toyota leaned heavily on the Daihatsu designs for quite a few engine developments, I think. Thank goodness, since it is easier to get Toyota parts than Daihatsu parts!
Though, now you mention it, I haven’t actually test fit them in the bore - should probably do that. I only did a quick sense-check with some vernier calipers when they got here.
Actual K3-VET pistons are rare as hen’s teeth (though I hear through the grapevine there are supposedly some suppliers in Malaysia).
Thanks - I’ll see what I can hunt down. Sulphuric acid is slightly tricky to get hold of - I’d have to get it delivered to my work address!
I have been using citric acid so far, and it has done really well on the lightly rusty parts, and was much easier to get hold of (and comparatively safe, too). But it doesn’t leave the piece completely clean.
I have edited what I wrote to say hydrochloric. That should be easier to find as it is used on concrete and such. I have fairly wide access to different chemicals as we have a chemistry department at work. For small parts I use something here available over the counter called Evapo-rust. It tends to leave things black etched. The stuff does not burn if you get it on yourself. Be really careful with the acid and I’ll state the obvious, always use eye protection, wash your hands after and douse anywhere you get it on yourself with running water.
Hydrochloric acid is, indeed, the mutt’s nuts where cleaning and de-rusting those last little areas. Have to be ready to do something with the part straight away to get it rust-protected, though. I left my test part out of the solution for a cup of tea’s worth of time and it had a coating of surface rust!
My cam bucket parts from Japan have arrived: that will let me re-build the head. I will try and remember to take photos as I go.
I hate spray painting. I might hate it less if I had all the right kit and a nice place to do it! Seriously considering just using a brush from now on… I might finish my bumper repair adventures tomorrow - again, will try to take some decent pictures.
I saw a turbo K3 engine going for cheap on ebay, and snapped it up. I started stripping it down last weekend, and found quite a bit of metal shavings in the oil pan, and score marks on the oil pump housing. Well, at least I have the exhaust manifold and (hopefully) a heap of spares. Perhaps most things can be rescued - a thought for another day, perhaps I can rope my “friend with a machine shop” in to do parts of it!
I also have pictures from my home made engine mount replacement - once I have all the pictures together, I shall post them.
Motivation has slumped a bit, but scrolling through the forums has reignited some enthusiasm - thanks everyone who posts and comments, great to hear other people going through similar struggles!
they made YRV’s in a 4trak? Wow, Australia missed out on so many nice versions of vehicles
It’s been a while and a half, but the YRV is back on the road!
I ended up not fitting the turbo or moving to an aftermarket ECU. Maybe later. I wanted to get it to a usable state, and after do long in the doldrums, a friend of mine kindly loaned me enough enthusiasm to make a big push.Processing: PXL_20241120_192241294.jpg…
Upgrades may happen in the future, but for now it’s going to be a workhorse rather than a project.
I have heaps of leftover, good parts that I’ll be putting in the “for sale” section one I’ve catalogued and photographed it all.
How were you able to solve that front brake backing plate problem? Did you re-install them looking like rust coloured Swiss cheese?
I solved it by ignoring it and just not fitting them!
It does bother me slightly, but I do have it in my head that I could fabricate something later and fit it without having to disassemble the hubs - either with a couple of screws or a jubilee clip and a part that splits in two.
The decision was made to prioritise having something usable over something that was as good as it could be. There are benefits to not having an immobile car in the garage all the time.
I had the same problem with backing plates on my first L601. My idea was to pour plaster of Paris or maybe concrete onto each plate, casting a mold. Thereafter, I could then hammer an aluminum sheet over the mold, resembling a crude stamping which would sufficiently serve its purpose. That would indefinitely solve any rust problem
Hi - Fantastic write up and inspiration. My little K3VE YRV is, and will never be more than a run around but I do want to pass it onto my daughter as her first car after she has learned to drive. The big problem - a misfiring engine under load and disappearing coolant, though no big overheats yet. I am guessing the head gasket needs replacing. Can a non-mechanic do it? Will I need to take the engine out or can it be done in situ? At 125 thousand miles I should also change the timing chain etc. Complicated and too expensive to be done by a garage. This is all new to me and I need to confidence and advice. Should I get started or get rid of the car?
I’ve seen a mechanic replace the timing chain, on one of those, with the engine still in the vehicle. He first removed the valve cover and somehow fed the new chain through. I didn’t stay there to watch how he did it. But, I think he somehow attached the new chain to the old one and then turned the crankshaft, until the old chain was sticking out, perhaps connecting both chains through a chain link. I’m sure that someone on this forum knows how it’s done. If looking it up shows no results, I would post a thread asking how.
I would find a throw-away car for your daughter, like maybe some ugly F.I.A.T. or older Renault Twingo, instaed of your valuable YRV. Beginning drivers aren’t as mindfull, considering vehicle value and diligent maintenance. This needs to be learned with time and maturity. If I was my own father, I would, in absolutely no circumstances, have given me a valuable car. I still remember having been a driving beginner. That’s the reason why.
A head gasket can be replaced, within the vehicle. Removing the entire drivetrain would take longer. But, doing this type of work with the drivetrain removed would be easier.
I would first attempt to find out exactly where the coolant gets lost, before tearing down the engine
Misfire under load may be easy fix- spark plugs may be worn
Hi - Spark plugs are fine. I have checked them with a gauge. The problem is definitely something more serious….unfortunately.
Thanks Butch. Funnily enough, I had just come in from looking despairingly under the bonnet and wondering whether or not to start when I read your response. I feel a bit more motivated again especially when you said the head gasket can be replaced with the engine in the car. as for the timing chain, I should do it but I wonder if it is beyond my limited capabilities.
Skiped timing also can gave whorse performance on WOT, but quite normal during crusing speeds
Good luck!
Just to confirm whether the head gasket has gone…….This rather sad video shows it has. Exhaust gases into the coolant - Blue coloured fluid to yellow.
Never a good thing to see.
