no, you just need the block and put the efel head on it. (aka Frankenstein)
[quote=“FrAsErTaG, post:18, topic:5842”]…I am unsure how much they would differ to the car mounted version…[/quote]That’s one fat flywheel:
[I’ve never yet seen a three-row balancer pulley on one of these yet:
Hopefully, they didn’t change the bellhousing’s bolt pattern, at Toyota’s request, like they did with the Citroen, Peugeot and Toyota Aygo series.
The lower horsepower may be due to an altered camshaft profile.
Where there’s an entire engine, there also must be an entire cylinder head available, separate from the block
Lower HP partly due to having to spin up that flywheel.
Thats a massive flywheel
[quote=“evilhighway, post:21, topic:5842”]…you just need the block and put the efel head on it…[/quote]Will the valve size be sufficient for handling the increased flow of the ED-20’s larger displacement volume?
Even so, the increased horsepower would be moved to a higher R.P.M. range (typical of all multi-valved head engines) of which would be ideal on the track. But would prove to be a disadvantage for hill-climbing of which low-end torque would be needed instead
don’t forget, that motor is out of a forklift so it won’t be made for all out power but to keep the motor inertia spinning, also they don’t have a dizzy attached and have an LPG carb setup, would love to have one just to say have a brand new ED ![]()
