Hi All,
Does anyone know where I might be able to source polyurethane suspension bushes for a 2004 Storia/Sirion? Parts here in the UK seem to be very scarce, and if I’m going to go to the effort of replacing bushes then I want to go for polyurethane, modern aftermarket rubber bushes are a load of rubbish.
TIA
If you have your old bushings, you can use them as a pattern for silicone molds, and then cast your own out of urethane. There are videos on YouTube.
Just to finish the story - the Siberianbushing.com bushes arrived from Vladivostok to the UK in 7 days, they are really good quality and I was able to fit them easily.
I need to have a look at the rear bushes - I have the parts but need to work out how to undo the bolts that run through the bushes, they are very tight and very hard to access.
But 10/10 for decent parts and prompt delivery. Recommended.
